TwinTurbo.NET: Nissan 300ZX forum - Sounds to me like you're missing pintle caps.
TriniTT
on October 07, 2014 at 3:33 PM
Z1 injector adapter kit
posted by Kvert
on October 03, 2014 at 06:34 PM
The injectors require good pintle caps to hold the lower orings in place. There's no way the oring can fit through the hole if pintle caps are installed.
Cheers,
JBrobst
Kvert
18:34:39 10/03/14
Update
Kvert
19:20:10 10/03/14
Same problem kris. New style injectors in OS rail.
ttz'in (NorCal)
03:18:38 10/04/14
Re: Same problem kris. New style injectors in OS rail.
WazTTed
03:22:51 10/04/14
Thanks Simon. I believe that's what Bernie uses in his
ttz'in (NorCal)
03:36:02 10/04/14
Kvert
07:58:11 10/04/14
Re: Re: Same problem kris. New style injectors in OS rail.
ttz'in (NorCal)
11:12:00 10/04/14
Installer error. (n/m)
TriniTT
11:20:51 10/08/14
No problems with CZP's injector adapter kit (n/m)
ThisIsSparTTa
10:06:27 10/04/14
Sounds to me like you're missing pintle caps. -
TriniTT
15:33:55 10/07/14
Re: Sounds to me like you're missing pintle caps.
Kvert
16:07:31 10/07/14
Pintle caps should be nice and tight.
TriniTT
16:47:48 10/07/14
Re: Pintle caps should be nice and tight.
Kvert
18:19:13 10/07/14
The jwt kit isn't functionally different than the z1 kit.
TriniTT
19:39:02 10/07/14
Re: The jwt kit isn't functionally different than the z1 kit.
Kvert
21:00:50 10/08/14
The adapters are designed to be the same shape as the newer
TriniTT
22:27:47 10/08/14
Kvert
22:29:21 10/08/14
Like I said before, the adapter is designed to be identical
TriniTT
07:27:12 10/09/14
Re: Like I said before, the adapter is designed to be identical
Kvert
19:27:12 10/09/14
Either injector should work fine.
TriniTT
11:08:18 10/10/14
Re: Either injector should work fine.
Kvert
15:02:45 10/11/14
Great! Glad you got it figured out, that's the sole purpose
TriniTT
14:53:02 10/15/14
Weird. I have the JWT Kit which the Z1 is similar to and
ZXRider
18:27:16 10/08/14
